oil leak at intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2011, 04:09 PM
I have an oil leak at oil sending unit on intake manifold how do I fix this and is it causibg vacuum leak as well
Old 12-20-2011, 04:18 PM
From your username, I'm assuming you're talking about a SB Chevy motor.
The oil sending unit is not associated with the intake manifold.
The intake manifold may be leaking NEAR the oil sending unit.
If there's also a vacuum leak, it sounds like you need to re-do the intake installation.
Old 12-20-2011, 04:28 PM
350 SBC correct it has rpm airgap eldelbrock and its the nylon tube or can use copper to the back by accel HEI
Old 12-20-2011, 04:30 PM
Correction its oil pressure sending unit my fault!
intake manifold leak dar timmons Engine 2 03-04-2011 10:19 PM
Questionable intake manifold leak tommy evans Engine 5 08-09-2010 12:14 PM
Intake Manifold Oil Leak - Smallblock 327 Chevy 64Joker Engine 9 11-18-2009 06:41 PM
Leak on top of SBC 350 intake manifold 75gmck25 Engine 9 01-23-2009 09:11 AM
Can oil leak out of an intake manifold? leastbay Engine 11 08-12-2004 01:55 PM
