Oil Leak---for The Life Of Me I Cant Find It :( - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2011, 01:22 PM
chevyrestore's Avatar
Hey everyone, ive got a 1959 chevy apache truck with a 1980 454 engine. Its been leaking around the oil filter area.
I put a new filter on it-no go
I removed the filter and the piece that the filter screws onto and sealed the mounting surfaces with auto grade silicone, then put on a new filter-still no go
Is there something im not seeing or something possibly next to it thats leaking?
Every time I look under there the drip is dripping down off the side of the filter but im almost 100% sure the filter or filter thread piece is not the cause of the leak.
Old 09-12-2011, 01:26 PM
DoubleVision's Avatar
Start looking above the filter for oil running down from the top or side.
I don`t know if BBC`s have the oil sending unit beside the HEI as the small block does, but if they do it can run from there down the bellhousing flange off the side of the block on the oil filter.
Old 09-12-2011, 01:28 PM
I looked on the driver side of the block and I dont see any leaks on the side of the block, I thought maybe it was the oil pressure line going to my gauge but thats not leaking either. I really dont see any leaks above it.
Old 09-12-2011, 02:17 PM
Back of the intake , valve cover gskt. , dist base gskt. , oil pressure gauge/ sending unit ? take a clean towel and wipe locations seperatly [ small section at a time , usually works for me .
dave
Old 09-12-2011, 04:53 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
What the number on the oil filter cartridge that you have on there?
Old 09-12-2011, 06:00 PM
sbchevfreak's Avatar
Licenced Automotive Technician
There is a pipe plug just above the filter housing on the block that is a secondary oil pressure sender location. It is possible that the plug is seeping past the threads...
Old 09-12-2011, 06:06 PM
ill check on that pipe plug.
as for the oil filter part number im using an STP this time.
I dont remember the number but this leak has been a 4 different brand filters and I compared all brand filters in the store and the STP had the thickest rubber seal so im almost positive its not the filter itself.
Chevy 350 oil leak. Can't find it. seawolf18 Hotrodding Basics 6 09-12-2011 04:30 PM
Cant find my vacuum leak.. stroker444 Engine 10 03-28-2010 12:54 PM
Frustrating Powerglide Leak or Torque Converter Leak? 67Elcamino Transmission - Rearend 2 08-26-2009 10:16 AM
How do I find a vacuum leak? KeithB123 Engine 2 09-21-2003 11:36 AM
How to find & fix a persistent SBC oil leak jpd37 Engine 16 09-15-2003 06:25 PM
