Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil leak from manifold.
Old 08-29-2012, 07:33 AM
delawarebill's Avatar
delawarebill delawarebill is offline
leak'n
i'm sure u did this.. but i mention it anyway..
if u gottta pull it again.. make sure u clean it good with a rag and brake cleaner... if u use the rubber gasket use some RTV top and bottom of it.. if not use a GOOD bead of RTV making use it ooz's out evenly... leave for at least a day to cure..
if u don't want to pull it again (can understand that), clean the area with bk clean and wipe with paper towel... put some rtv on your finger and press it in the mating surface, let that cure too...
