oil leakage small block chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2009, 08:47 PM
i have a small block 350 chevy motor that is leaking oil like a sponge and im having a real problem finding where from. the pan gasket is not leaking, the pressure guage is fine, the front and rear seals are fine, and the valve covers are fine. it appears there is wetness around the cylinder heads and also running down the transmission housing from the rear of the engine. im wondering if the heads could be seaping yet still run fantastic..no smoke, doesnt use water. any suggestions before i tear into the motor. oh and this is a brand new rebuilt engine just assembled and installed. thanks tony !
Old 05-12-2009, 08:57 PM
ericnova72's Avatar
More for Less Racer
The seal at the back of the intake where it meets the block? Common leak spot.
Old 05-12-2009, 09:00 PM
DoubleVision's Avatar
Look on the front of the engine by the harmonic balancer, beside it on both sides you`ll see 2 bolt holes. These were put there for the original mounting points for the engine, however, the top bolt hole on the passengers side runs into the fuel pump push rod, if there`s not a bolt in this hole, oil will come out of this hole off idle. Often a short bolt with sealant is put in this hole as if the bolt is too long it`ll make contact with the fuel pump push rod.
Here`s a example:
http://www.chevytalk.org/fusionbb/pr...hp?tid/182728/
Check to see if this bolt is in place.
Old 05-12-2009, 09:01 PM
fast68's Avatar
likes chevy trucks & boobies
and distributor base gasket is a common one as well, sometimes it is forgotten about
Old 05-12-2009, 10:42 PM
chevy oil leak
check to see if the oil pressure sender is tight and sealed. sometimes during installation the sender can get cracked or loosened.
Old 05-13-2009, 09:10 AM
it does have the bolts by the fuel pump and not leaking and also the dist. is fine and the sending unit is fine. the intake gasket sounds like a good possibility and ill check that next. however nobody has ruled out for me the possibility of the head seapage question ?. could someone please address that question. thanks for the input Tony!
Old 05-13-2009, 09:18 AM
Oil only drains back into the block via the drain holes, there`s no other place for it to go, if it were coming out of the gaskets it would have to travel a long way. Since you have it on both sides of the engine it sounds like the valve cover gaskets, if you can remove a spark plug and find oil on the threads you found the problem. The oil will leak out from under the gaskets, down the head and fly back from there. Are you using a PCV system?
Old 05-13-2009, 10:21 AM
the valve covers are completely dry all the way around and there is no oil above headers, only below. yes i am running pcv.
Old 05-13-2009, 10:28 AM
Sorry Tony, I`m stumped.
Old 05-13-2009, 11:38 AM
When the engine was re-built, did they use the rubber gaskets for the front and back of the intake manifold? If they did, chances are that's where it's leaking. If there's been any machining on the head/block/intake, they won't seal. If it's a rebuild that you paid for, make them fix it. If not, it's not that big of deal to pull the intake and seal it.
http://www.hotrod.com/techarticles/m...end_seals.html
The spec for the gap between the block and intake ends is 0.090". Most of the ones that I've seen aren't anywhere near that. I've seen them as small as 0.030 and as wide as 1/4". On the last one, we got the intake machined to get it down to 1/8".
Matt
Old 05-13-2009, 12:40 PM
Is the leak particularly heavy and noticable on the left side? There is a pressure line plug installed in a pipe tapped hole on the rear of the head deck surface, in the block, but approximately at the #7 Exhaust valve pushrod location, aft of the head. Usually, about half of the plug is visible, and half is hidden below the cylinder head. The plug might be loose and leaking.
Pat
Old 05-13-2009, 01:51 PM
well if the plug were loose or leaking that would mean head removal...correct?
Old 05-13-2009, 01:53 PM
I've not seen one that could be tightened with the head in place. Verify before you disassemble.
Old 05-13-2009, 03:22 PM
I,m betting on the intake seal, I had one that I was not getting a big enough silicone bead and it would leak again. I was always able to get my hand to the back of the block and run my finger along and I would find the oil running down the back of the block onto the starter and dripping. the oil pan and seals were not the problem. As stated above, make sure the distributor seal is not also leaking. It took me three different times before I finally got the silicone beads correct for that motor. Good luck.
Old 05-14-2009, 10:52 AM
bobjob's Avatar
this sounds a little strange... but hows the exhaust system? if muffler or cat. converter is plugged-up.. backpressure in engine will increase and start blowing oil out of everywhere .just a guess and i'm probably wrong! guess i just need to work on typing skills.
had a few do same thing, spent a few too many dollars and time chasing leaks before i found problem.
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
Why I have Always LOVED the Small Block Chevy A glimpse inside reality Rob Keller Hotrodders' Lounge 54 11-09-2007 07:30 PM
My 350 Small Block Chevy. What do I have? Frank the Tank Engine 29 09-08-2007 06:33 PM
7qt Oil Pan & Pickup SBC Small Block Chevy Mustangsaly Engine 6 06-12-2005 07:52 PM
need info on small block chevys engine-rookie Engine 1 05-03-2003 08:48 PM
