Oil leaking from battery cable ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2013, 01:06 PM
Bobs36ford's Avatar
Last journal entry: Video of new upholstery
Hi
My 36 fORD HAS THE BATTERY IN THE TRUNK. THE CABLE IS #2 GAUGE. I DISCONNECTED THE BATTERY AND LET THE CABLE HANG DOWN OVER NIGHT. THIS MORNING I WENT OUT TO RE CONNECT THE CABLE AND BELIEVE IT OR NOT A PUDDLE OF OIL HAD RAN OUT OF THE CABLE. GO FIGURE???????
bOB
Old 03-02-2013, 01:20 PM
oil leak
There is no oil in a battery cable. Only thing I can figure is that you have an oil leak that is dripping onto the cable and then running down it .
The Following User Says Thank You to snakebit68 For This Useful Post:
Bobs36ford (03-02-2013)
poncho62's Avatar
Wiki Edits: 5
Maybe oil is leaking where it is bolted to the engine/tranny and running along it?
The Following User Says Thank You to poncho62 For This Useful Post:
Old 03-02-2013, 03:30 PM
LATECH's Avatar
X 2 with poncho.
Fact is stranger than Fiction
Old 03-02-2013, 06:51 PM
Possibly something leaking oil, ive heard of this happening before where the oil absorbs into the insulation of the wire, and will work its way to the loweest point, .....
The Following User Says Thank You to HunterJ For This Useful Post:
Old 03-02-2013, 08:41 PM
evolvo's Avatar
That's not oil, it's liquid smoke. If you develop a short this liquid smoke becomes a gas, it has an acrid burning smell. You'll be able to see it clearly then!
Old 03-03-2013, 03:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good one!
If the cable was ever laid in a place where there was enough oil that the oil could reach the level of the wire inside the insulation, the oil will wick up inside the cable through capillary action. This could continue until the oil level dropped too far or the cable became full.
The only real concern I would have is if there WERE a short, the oil could conceivably catch fire and burn the vehicle to the ground. So if it's practical to do, remove the cable and flush it out using something like Black Maxx from NAPA (like 409 cleaner on steroids) followed by rinsing it w/water, before returning it to service.
Old 03-03-2013, 03:55 PM
bigdog7373's Avatar
Of course it's fast
Could it possibly be condensation mixing with something inside the cable like a sealant or something?
Old 03-03-2013, 09:36 PM
Greg T's Avatar
www.krusinklassics.net
No, it's volt lube. They put oil between the wire and the insulation to make the current slide through the wire better. Less resistance!
The Following User Says Thank You to Greg T For This Useful Post:
Bobs36ford (03-04-2013)
Old 03-04-2013, 06:32 AM
Bobs36ford's Avatar
Originally Posted by greg t View Post
no, it's volt lube. They put oil between the wire and the insulation to make the current slide through the wire better. Less resistance!
lol lol lol
th350 leaking near kickdown cable kuta1972 Transmission - Rearend 5 11-19-2011 03:12 AM
Question on leaking kickdown cable badA31 Transmission - Rearend 1 01-26-2008 07:31 AM
Battery Cable Tbucit Electrical 10 11-29-2006 09:54 PM
Battery cable Marcus Electrical 6 03-29-2005 11:51 PM
Battery cable bct Electrical 5 10-08-2004 12:52 AM
