-   -   oil leaks (http://www.hotrodders.com/forum/oil-leaks-29571.html)
carnell 12-06-2003 09:51 PM
oil leaks
ok about 2 mounths ago i put a new intake gasket set on my 351 clevo in the instructions it said put no sealent on those snakey little rubbers on the end and none between the tin valley cover and the intake.
i noticed the other day that oil is sitting in that little well where the oil sender unit is but i can not feel any oil running out the back of the intake. cold it be that it is leaking around the sender unit??
lluciano77 12-06-2003 09:53 PM
Try wrapping plumbers tape around it. Use that thin thread sealant.
Jmark 12-06-2003 09:54 PM
Ford sending units are notorious for leaking. One day dry, next day puking all over the driveway. Clean off the top of the sender where the metal is crimped on the center plastic piece. Start it up and look for oil seaping out of the crimp.
Mark
lluciano77 12-06-2003 09:56 PM
Good point. It could be at the electrical connection. If so I would get one of those Auto Guage 3 guage sets. It is a lot nicer to be able to actually see what you oil pressure is as opposed to an idiot light that comes on when it is too late if at all.
carnell 12-06-2003 09:57 PM
ill do that because i dont realy what to have to buy a new gasket kit
lluciano77 12-06-2003 10:00 PM
I don't know if they have them yet for Clevelands, but if you do need to get another gasket set there is one called an Ultra Seal II. They are made by Mr. Gasket and they are re-usable. I have re-used them on my Chevy 3 times and they keep sealing.
carnell 12-06-2003 10:02 PM
no it doesn't have a light it has got a factory gauge
the one i got is from felpro
4 Jaw Chuck 12-06-2003 11:36 PM
Take it apart and toss the end seals and replace them with a healthy bead of RTV, the Felpro gaskets have a non-stick surface so they should be reusable. Fords are notorious for a leak in that area, most times it's the intake end seals that are the problem. Change the sender while your in there, they are cheap and it would be the best time to change it.
troy-curt 12-06-2003 11:44 PM
Like the jaw I through all the rubber seals away and use a good RTV.on everything, On the mating surfaces I use a punch about every 1/4 inch to give the RTV something to bite. HTH
Troy
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
carnell 12-07-2003 09:23 AM
i normaly use lock tight sealent is that alright to use??
carnell 12-14-2003 08:31 PM
its called blue max rtv silicon
