oil leaks from hp oil pump??...help please!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2012, 01:03 PM
I have a 406 sbc motor with large oil pan and 485hp and torque. I had a massive blow out through an o ring in a sandwich adapter from oil cooler. I replaced the adapter and o ring. Now i have little oil leaks a few weeks later all over the place. My oil pressure is @ 85lbs at start and 72 at warm idle. Also my fuel pump was getting wet and was under the impression it was a bad fuel pump as it is hp also....and seems high with 6.5 lbs of fuel pressure/// but it is oil on top not gas..now the sandwich adapter seems to have oil running down the oil filter...so before i replace every seal and gasket could it be this high oil pressure killing me with leaks ?? any help would be greatly appreciated!!
Name:	chevelle red valve.jpg
Old 06-04-2012, 02:00 PM
Richiehd's Avatar
JS-70
Wow, thats a lot of oil pressure at idle. However, do you have breathers and PCV on that motor? Both covers?
Old 06-04-2012, 02:16 PM
What type(weight) of oil?
That pressure is excessive, 80lbs cold will burst a filter or pop the filter gasket.
Whats the pressure at 3000rpm warm?
Old 06-04-2012, 02:51 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Yes, your oil pressure is wayyyy too high. You need to either change the pressure spring or go to a high volume pump. You could use a stock pump on that motor with no problems. The excessive pressure is your problem.
Old 06-04-2012, 03:48 PM
I have a breather on one valve cover and was running 10w 30 mobil one and switched over to 10w 40mobile one ....So i need to replace the hp oil pump with hv oil pump ...ill check the 3000 rpm pressure tonight and respond. thanks for all the input.
Old 06-04-2012, 03:55 PM
cool rockin daddy's Avatar
What is this engine used for? If street use, put a standard pressure, standard volume GM pump in it. Don't need anything else.
Old 06-04-2012, 04:08 PM
I do daily driver it but occasional drag strip also.... it gets some what of a beating at the drag strip but it will be once every couple of months.
Old 06-04-2012, 04:15 PM
I've built lots of racing engines that have 75psi pressure with 140 degree oil at startup. After a couple hours at WOT, they idle at 35psi. The filter should be able to withstand 150psi without leaking. The leak out the weep hole in the fuel pump can be fixed by plugging it. I use a rivet with RTV on it.
Old 06-04-2012, 07:15 PM
so ....Ive looked around the site and this is what im finding ... My oil smells like gas and i have oil slung all over the place..and yes atop the fuel pump. So besides having to get a new oil pump it seems like my fuel pump has been compromised as well as slinging oil all over the engine through the weep holes. The car sat for a few years so i guess this is what happens with that oil pressure and old seals and such...and changing the oil AGAIN...man this sport is no joke when it comes to the pocket!! and after i do all this im sure the rings are next and the head gaskets too....no crying in motorsports huh?
Old 06-05-2012, 05:32 PM
6426yy's Avatar
Your not running a PVC valve? I'd start there and drop to a lower viscosity oil before I pulled it apart.
i have a 70 buick 455 fresh bottom end and new high out put oil pump still no oil pre tpisuper10 Engine 12 09-22-2008 09:26 PM
oil leaks mrobby440 Engine 2 05-14-2007 02:24 PM
Please help to diagnose- engine with no oil pressure. Oil pump failed? killerformula Engine 4 12-26-2006 10:25 PM
oil leaks carnell Engine 10 12-14-2003 07:31 PM
HV oil pump makes oil filter seal leak WBrianS Engine 13 11-20-2003 01:56 AM
