Oil Level in TH350, how to find out ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2007, 10:03 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I'm installin' a TH350 in a custom swap, the problem is I need to use a very short custom made dipstick tube and corresponding dipstick, I lost all refferences of the oil level, anybody knows where the normal cold oil level is? measured from the bottom of the oil pan to the oil surface? or from the edge of the filler tube hole in the case to the surface of the oil?
please help.
Thanks.
Augusto.
Old 05-27-2007, 12:51 AM
jakeshoe's Avatar
Fill with approx 3-4 qts of fluid, loosen the trans pan bolts, let the excess fluid drain off, re-tighten the pan, install your dipstick. The fluid level on the stick will be correct for warm, running, in park. Mark the stick here, then fill as needed to obtain that level under the above conditions.
Old 05-27-2007, 08:29 PM
Augusto's Avatar
so you mean the oil level is flush with the pan mounting flange?
Augusto.
Old 05-27-2007, 09:01 PM
DeathRattle's Avatar
Some Punk Kid
I believe thats what he is driving at.
When the fluid is at top of pan, no higher or lower, put the dipstick in and mark where the fluid is at, at that level.
After that if the trans was completely empty before doing this, I believe the TH350 takes an average of 9-10 total quarts of fluid.
Old 05-27-2007, 11:42 PM
jakeshoe's Avatar
Yes,
the warm, running in park oil level would be flush with the pan mating flange.
Old 05-28-2007, 01:42 PM
Augusto's Avatar
Thanks a lot.
Augusto.
Old 05-31-2007, 12:15 PM
bentwings's Avatar
bentwings
Thanks for answering a question before I even asked. What are ya, a mind reader.??
This will fit perfect with my clean under the hood criteria. I planned on not even having a dip stick. After all the trans doesn't burn oil like a motor can. If it leaks ...fix it.
A sight glass on the side of the oil pan?? And no engine dip stick.?? Motor cycles have them.
Old 05-31-2007, 02:19 PM
Augusto's Avatar
some japanese cars have a brake fluid sensor that turns a ligth on when the fluid goes low, it's just a float that closes a circuit when it goes down, install one of them gizmos in the oil pan and you won't even have to look under the car to find out about your oil level, install a plug in the tube hole for filling the tranny.
Augusto.
Old 06-03-2007, 10:59 PM
My '88 T-bird has one of those oil level lights. It started lying early-on. The dipstick still works OK at 180K. Guess which one I trust?
Old 06-03-2007, 11:23 PM
if you were to put an oil light it would need to be positioned in the right spot on the pan as to not get uncovered while accelerating or braking/turning that would be kinda annoying if it kept flashing on and off
Old 06-04-2007, 01:00 PM
Augusto's Avatar
a simple baffle should take care of that.
Augusto.
Old 06-04-2007, 11:21 PM
yeah it would work with a baffle but i dont think there is much room in the pan to work with.
Synthetic oil?? Mightymouse Engine 40 02-23-2012 04:05 PM
Synthetic Motor Oil In 454 Rebuild leejoy Engine 36 11-20-2006 02:34 PM
low engine pressure molevolent_creations Engine 14 12-24-2005 07:49 PM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 10:27 AM
ATF at oil change mitmaks General Rodding Tech 10 10-25-2003 02:11 PM
