Oil lost through rear seal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2005, 11:57 AM
The oil level in my 383 keeps going down since the rebuilt time..about a quart for 600 miles.
I've discussed here many different possibilities explaining this without being able to conclude to nothing sure yet.
Everytime I'll come back from a ride I noticed a drop of oil present at the bellhousing lower part.I kind of made sure this is not from anything leaking higher on the engine like leaking valve covers,distributor base,intake manifold,oil sender hole etc..the block is dry and clean. So I can think about the oil pan gasket rear portion or crank rear main seal wich is a two part one (old 1970) block.I can't reach under the car and inspect it good now but lets we supposed it is one of these. Now when parked after a run it will be really only a few drops then it looks like once cooled it stops.
My question is how much oil could actually seeps through the seal or gasket while the car is actually underway? Is it likely to leak much more underway than parked? The undercar area is clean not having traces of oil sprayed around..if leaking that much from there could it not leave any traces on the undercar...Well I guess its not an easy one to answer but who knows maybe somebody here could have seen similar situation..mind you I think I'll have to proceed to a leak down testing soon!
thanks,Ronald.
Old 11-09-2005, 01:09 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Oil pan gasket, rear main seal, can bearing tunnel plug, oil gallery plugs near the cam rear plug. Or a crack?
Engine swap (1 piece -> 2 piece rear oil seal bwery Engine 3 01-31-2005 09:39 AM
Rear of engine oil leak 350 western star Engine 5 07-13-2004 03:32 AM
Rear Gear Oil Problem. help 71gtx Transmission - Rearend 4 03-03-2004 07:26 AM
350 chevy oil leak in rear of engine eric302 Engine 11 09-04-2003 07:49 AM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
