Oil in manifold plemun - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 06-30-2007, 06:28 PM
I got a friend who is running a Chevy 383 with headers and World Product Aluminum Heads. He is getting an oil residue in the bottom of the manifold plemun. He pull the manifold and replaced the intake gaskets and had the valve seals checked at a machine shop and was told they are fine. Anyone got any ideas to why he would be getting oil in the bottom of the manifold?
Old 06-30-2007, 07:17 PM
383silverado's Avatar
does it have a real lopey idle ? maybe it's from valve overlap meaning that some exhuast coming into the intake runner this is what causes that lopey idle .
Old 06-30-2007, 07:38 PM
willys36@aol.com's Avatar
Wiki Edits: 21
If he has a tranny with a vacuum modulator (i.e., TH350), it could be a ruptured modulator diaphragm and tranny fluid and not engine oil.
Old 06-30-2007, 09:08 PM
is the pcv sucking oil?
Shane
Old 06-30-2007, 09:43 PM
econoaddict's Avatar
Last journal entry: project delays
If this is the same one that has multiple pages on the subject on another board I say its the intake gaskets leaking and/or he had the block decked and didn't get the manifold machined to the correct angles.
The reasoning behind this is:
First he had a plug fouling and the oil in the manifold, he then changed the intake gaskets and after this he had a different plug fouling along with the oil in the manifold.
He changes the gaskets and the plug that fouls changes......make sense?
If the block was decked and/or the heads shaved this changes the angles where the head and manifold meet and the manifold will need machined as well or he will fight the same problem for along time.
If this is the same one, he posted a pic of gaskets that were "sealed" they showed a large amount of silicone that squished out when things were tightened, this could be the problem as well...that much silicone should not be needed on an intake.
If this isn't the same as the other forum please delete this.
Old 07-01-2007, 10:19 AM
Good questions, again this is a friend who called me up. I will ask him to see about your suggestions. Thanks, and if anyone else has an idea, please let me know.
Old 07-01-2007, 12:38 PM
Nope, he is running a 5speed tranny.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
oil leak rb8179 Engine 11 06-03-2006 03:07 AM
Oil Filter relocation kit... jmbjs Engine 4 04-11-2006 08:15 AM
low engine pressure molevolent_creations Engine 14 12-24-2005 07:49 PM
