oil on my air filter - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2011, 07:35 PM
I Have 93 Caprice 5.7 350 And I Have Oil On My Air Filter, Does Anybody Know What Would Cause That To Happen?
And Im Leaking Oil Right Above My Trans, I Changed My Valve Cover Gaskets And Im Still Leaking, Could It Be My Intake Manifold Gasket?
Old 05-18-2011, 07:41 PM
tnsmith10's Avatar
when will it rain???
it could be the intake manifold, or the oil sending unit.
as far as oil on your air filter, that also could be from the front of the intake leaking and the fan blowing the oil back to the air filter.
Old 05-18-2011, 07:48 PM
The Oil Is Coming In From A Hose Connected To The Valve Cover On The Passenger Side, Not The Pcv Valve Side, Im Trying To Figure Out What Is Pushing Oil Thru This Hose
Old 05-18-2011, 08:33 PM
willowbilly3's Avatar
Last journal entry: Body mods
Clean it up good and install a new pcv valve. The side that's leakinf is where air is allowed to go in as the pcv sucks but is also vents uncer conditions when the pcv can't suck it all up. If the pcv isn't clogged, either your engine is really tired or you are hammering it a lot.
Old 05-18-2011, 09:18 PM
I Changed The Pcv Twice And I Cleaned It When I Changed The Valve Cover Gaskets
Gas filter rustman General Rodding Tech 16 04-28-2011 12:31 PM
Changing the filter in the FRAM HPG-1 fuel filter assembly tombguard Hotrodding Basics 3 08-18-2009 07:24 PM
Looking for a fuel filter cover or a metal fuel filter. Suggestions? (pic) rajsid Engine 3 08-05-2009 08:31 PM
Milodon oil pan...7 qt w/ filter or + filter? Finmike Engine 6 07-05-2004 11:44 PM
air filter K&N APACHEMAN Engine 10 08-12-2003 12:03 PM
