Oil on Oil filler cap NOT on dipstick. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2010, 03:24 PM
Just completed changing Intake Manifold (RPM Edelbrock Air Gap) on Small Block Chevy Eng (400ci). Engine recently overhauled by Ed Hale Racing Engines of San Diego. After 2 complete warmup cycles (180/185 Degs) Noticed "Oil Breathers" on both valve Covers were "Milky". Exhaust was shooting some condensation. Car has been sitting for approx: 3 weeks, without any engine starts. "Right away, I figured Blown Head Gasket?? BUT, Dipstick shows no evidence of oil in the system. Engine was professionally built and Dyno'd. All that has been done is changed Tunnel Ram Intake for Edelbrock. Any suggestions would be appreciated.
Old 01-26-2010, 03:34 PM
SSedan64's Avatar
More than likely just condensation. Keep a check on the oil & water tho'. It has been pretty wet in Ca. lately.
Old 01-26-2010, 04:02 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Are you sure it has the correct dipstick in it ? I would drop the filter and check to see if it has any oil in it and also drain the oil and see how much is in it also and if there is plenty in it make sure about the dipstick. JMO. And you might need to be getting in touch with your engine builder if all is not right. How recent is the overhaul?They should stand behind their engines if it's a good company anyway. JMO
Cole
Old 01-26-2010, 04:11 PM
CQNRQY
No Oil on the dipstip?
If there's no oil on the dipstip. I'd be concerned.
Don't run it till you confirm you have oil.
If a head gasket goes you can tell by pulling plugs and inspecting them.(One very clean one compared to the others)
It may also be noticed, if you have a lot of pressure in your cooling system (bubbles in the rad when running),
I'd do a compression check too.
Condensation is normal in this type of weather.
Good luck
Old 01-26-2010, 04:33 PM
SSedan64's Avatar
I think/hope that was an error. I think he intended to say "dipstick shows no evidence of water"
Old 01-26-2010, 04:38 PM
Thanks, SS. Will monitor radiator and Oil. It has been pretty cold for us Southern Cal Boys. BRRRR. It actually Hailed last week.
Old 01-26-2010, 04:45 PM
Good luck
Pulled Oil Drain Plug, NO evidence of water in oil. Pure oil surfaced. It has been a little on the cold sirde for us down here. I imagine the garage must really get cold. Non-insulated.
Old 01-26-2010, 04:47 PM
Good luck
I was thinking along the same lines. Cold in Southern cal. Pulled Drain plug, found no evidence of water.
Old 01-26-2010, 04:50 PM
SSedan64's Avatar
This thread has the "Milk" issue also. >> PCV Valve good PCV Info.
Todd
383 #5 Bearing Cap Oil Plug fzr989 Engine 12 05-28-2008 05:25 AM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 05:26 PM
oil leak rb8179 Engine 11 06-03-2006 03:07 AM
Oil Preshure ve3ham Engine 9 10-28-2004 02:36 PM
Oil Filler Question horvath Engine 2 03-17-2003 01:52 AM
