Oil Pan for 377/383 small Chevy V-8 stroker?
I've seen 3.75" cranks with small journals, and many 2-piece oil-seal pans are available for those. What about pans for late model 1-piece 350 blocks using a 1-piece-seal crank that have been clearanced? Can a stock 350 pan still work or is a bigger/clearanced pan necessary?
When you go from a 350 crankshaft ( 3.48 stroke ) to a 400 crankshaft ( 3.75 stroke ) the stroke goes up only .270 thousands. The stroke is up/down so the rod is only .135 further down towards the pan with a 400 crankshaft ( over a 350 crankshaft )
That is barely over 1/8th of a inch I have never had to get another oil pan on the 383 strokers I have put together but I have also never built a one piece seal 383 ... I try to use the 1990 Corvette oil pan ( 6 quart ) on all my one piece seal SBC's anyway ... |
| Wich oil pan you use on your 383 stroker? | TVR383 | Engine | 10 | 01-30-2007 07:21 PM |
| Jiffy lube rant: what would you do? | killerformula | Hotrodders' Lounge | 35 | 02-16-2006 06:07 PM |
| can the wrong oil pan make this sbc leak? | bigwildgrin | Engine | 10 | 12-19-2005 06:33 PM |
| Front oil pan seal on Small Block Chevys | gearhead77 | Engine | 19 | 09-26-2004 08:58 PM |
| Oil pressure loss SB Chevy | Finmike | Engine | 30 | 06-12-2004 10:27 AM |
