Oil Pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2002, 08:34 PM
Red face Oil Pan
Ahhhhh! I need to remove my oil pan on my 68 Camaro but the fly wheel and steering linkage has got it trapped. Any suggestions. Thanks
Old 11-04-2002, 08:39 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Maybe lift the motor off it's mounts a little.
Old 11-05-2002, 07:24 AM
34FordPickUp's Avatar
Post
There is a way! Find a Helms manual for the Camaro. It outlines positioning the crank to allow clearance. I removed the pan from my 67, but that was in 70 or 71 and my memory on what exactly to do isn't that good!
Old 11-11-2002, 05:59 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Drop the steering linkage down from the ideler arm would be the easiest, use a pickel fork for the proper way to take it down.
Luv the smell of NITRO in the morning.
