oil pan baffle - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2005, 04:47 PM
oil pan baffle
I changed motors in my car from a small block chevrolet 283 to a 350. The 350 had a deep pan on it so I swapped pans. I used the pump and pickup from the 350 but took out the spacer that made the pump lower for the lower pan. When I am going down hill and hit the brakes My oil pressure drops off drastically and if I am not completely full I lose oil pressure completely. I am leaking at the front seal and am going to tear it apart. What do I need to do to the pan. I don't think there is any baffling in the pan that is on it. Do I need any?
Old 08-18-2005, 10:17 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Yes you need a baffle. Even stock engines use them. My 354 hemi does anyway, can't remember if SBCs do or not. Anyway, they do work.
Old 08-19-2005, 10:57 AM
Siggy_Freud's Avatar
My stock 350 pan has a baffle in it.
Bringing history and technology together.
Old 08-21-2005, 05:42 AM
Baffled?
I can't say all, but every post 68 sbc i've seen had a baffled sump. I have cut a baffle out of a damaged sbc pan and used it in a 308 Holden, and made one similar to fit in a Falcon 351c sump. Sounds like you need one, and a trap door wouldn't hurt. Talk to a local dirt track racer for sources.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
Milodon oil pan...7 qt w/ filter or + filter? Finmike Engine 6 07-05-2004 10:44 PM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
