oil pan on concord
Hi guys,
So I f**ked it up real good. The engine oil drain plug on my 2002 concord. The head was bad so I unscrewed it with the vice grip plier. Not having a new drain plug available I just screwed it back in with the plier. Now the next oil change, I have a new drain plug but I cant get the bad plug out! by now the screw is pretty much perfectly round from all the different tools I tried. I grounded 3 flats on it but the screw DOES NOT COME OUT! So I got me a new oil pan gasket and went ahead on Monday to take the whole oil pan of and fix it on the bench. According to my manual the pan comes right out after you take out the transmission to oil pan bracket and take off all the bolts. That was already another prime example that the Chrysler designers must not like mechanics at all or why in world would you put nuts on studs right above the engine cross member were you break you fingers to get to them. Anyhow, I got all out but not the oil pan. It gets stuck on the tranny housing. I was missing about 0.07" or so to get it by that housing. About nothing I know but enough to not make it come out. I was pushing her and prying there but with all the cast aluminum I stopped not to break anything. I just screwed it all back in and called it a day. I had the car on the ramps instead of on jacks. you think or know that this would make a difference? Any other ideas on how to get either the screw or oil pan out? Any hint will be greatly appreciated! Thanks Guys. Tomi |
No Ideas? I really could need a couple hints!
they came with the 3.5L too
Sorry missed to mention its the 3.5 V6.
Never the less that screw and me are no friends! However, thanks for all the ideas and suggestions. I do have a lil welder and I will try the nut weld. Thats a real good idea. But keep it coming guys. I could try taking the filter of but how does that make more room? The front of the pan hits the serpenting belt pulley on the crank and the tranny case in the back. And I didnt feel like taking that pulley off because tighten that belt again is another great adventure. I did that when I had to change the alternator and again when I changed the thermostat. But by then I had the hole already in place to get the alternator mounting screw out! Because lifting up the engine about a foot was not an option. That car is not made to be garage wrenched on. I wonder how the pros do all that in a reasonable time??? But that just besides my issue. |
the filter is probably irrelevant on the subject now because like i had mentioned, i was figuring that your concorde had a 2.7l from what you had described gl p.s. if the 3.5 is anything like the 2.7 when it comes to the balancer, you will need a special puller to get that balancer off. Last edited by tnsmith10; 09-11-2009 at 05:40 AM. |
sometimes
sometimes you have to rotate the crankshaft so certan throws are up. I don't know if that applies to your engine
| SBF Oil Pan Gasket Problems | coda618 | Engine | 12 | 04-14-2010 05:11 PM |
| Oil Pan Help Big Block Chevy 454 | 71 nova | Engine | 0 | 08-18-2008 09:51 AM |
| Z-28 Windage Tray / Oil Pan Clearance Issues | ezobens | Engine | 1 | 03-25-2007 01:48 PM |
| can the wrong oil pan make this sbc leak? | bigwildgrin | Engine | 10 | 12-19-2005 06:33 PM |
| Oil pan - kicked out sump good? | dh79 | Engine | 4 | 06-15-2005 01:32 PM |
