Oil Pan Depth - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2008, 10:09 AM
Last wiki edit: Quadrajet
Wiki Edits: 7
Oil Pan Depth
Ok, so I am buying my new oil pump and was planning on one that has the pickup included and tack welded on to the pump. However, I don't know what the oil pan depth should be. I have to use a stock oil pan so I just need the stock small block chevy oil pan depth for a 283.
Old 04-21-2008, 11:10 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Usually the oil pan manufacturer will either include a pickup, or make one that is correct for the pan. Then you can install the pickup and take it to a machine shop and have it TIG or Heliarc welded. Don't use MIG, stick, or brazing. The bypass spring is right beside what you are heating and its very sensitive to fatigue from overheating. Some pumps also have plastic bushings inside that could melt.
The pump itself is also cast iron. Welding cast iron can very easily send hairline fractures through the casting the moment the arc hits.
A better idea is a pickup that bolts on, or just skipping the welding. If you're going to weld anything, I say install the pickup, then bolt a piece of strap steel to the mounting bolt and weld that steel to the pickup tube.
GM didn't tack weld them on, and I've never known a company more willing to spend 3 cents of prevention than GM. Welding cast iron is a very scary proposition, especially on something as critical to the engine as the oil pump.
Old 04-21-2008, 01:58 PM
Wiki Edits: 7
Summit sells rebagged oil pumps that have the pickups already welded onto the pump housing and that is where I was looking. While pickups falling off may not be an everyday occourance, it does happen and a tack weld insurance policy sounds like a bargin to me! There are some that have a bracket that comes with the pump that bolts to the housing instead of welding.
Honestly, Weld or bracket I don't care but either way I need to know what the stock pan depth is so that what ever I order is right! This is my new circle track motor and I'm past the point now where I can order something wrong and have time to return if for the right part! My first race is 3 weeks away and on saturday I punched a rod out the side of my oil pan on my current motor.
Old 04-21-2008, 05:45 PM
techinspector1's Avatar
Wiki Edits: 326
Install the pump. Fashion a cone of oil-based modeling clay about the size of a dime at one end and tapering down to about the size of a pencil eraser at the other end and about 3/4" long. Mash the big end onto the flat surface of the oil pump pickup after de-greasing the flat surface. Rub a little oil onto the interior of the pan on the bottom so the clay will not stick to the pan and push the oil pan up into place, making sure to push up moderately on the area where the clay is and fit the pan up against the block all around. You won't need the gasket in place to do this. Remove the pan and measure the height of the clay column. The pickup should be 1/4" to 3/8" off the bottom of the pan and the clay will tell you the clearance.
Z-28 Windage Tray / Oil Pan Clearance Issues ezobens Engine 1 03-25-2007 01:48 PM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
Stripped oil pan? zacritz929 Engine 13 01-02-2006 11:17 AM
can the wrong oil pan make this sbc leak? bigwildgrin Engine 10 12-19-2005 06:33 PM
ZZ4 Oil Pan Depth silvernblack Engine 2 06-11-2003 06:33 AM
