Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil pan depth
Thread: oil pan depth
Old 11-11-2012, 02:55 PM
azlogger azlogger is offline
Last journal entry: Front suspension update
Originally Posted by techinspector1 View Post
If the car was originally rear steer, swapping the spindles side to side to make a front steer car will not work. I don't know what you had in mind, I'm just trying to read ahead.
as i said, i'm scratchbuilding this car so i don't have an "original car". in this case i will just have to use the front spindles from a vehicle with front steer. i was planning to go with pre-1981 ford truck spindles(which are rear steer), so i'll switch to post-1981(which are front steer). but if you foresee any problems with this please let me know!
