-   -   oil pan depth (http://www.hotrodders.com/forum/oil-pan-depth-225878.html)
azlogger 11-08-2012 08:37 PM
oil pan depth
Hi, i'm scratch-building a car and need to know how deep the oil pan on a 350 chevy is at the FRONT. My steering linkage will have to go under the pan just a few inches back. I know there's a lot of different pans out there but i'm talking about just a standard, stock chevy pan. thanks
BOBCRMAN@aol.com 11-08-2012 09:00 PM
There are many different stock SBC pans. You will have to be more specific.
cobalt327 11-08-2012 09:18 PM
On my factory Vortec 350 pan (it's similar to the one below) I'm getting about 3-3/4" from the pan rail to the first (front most) step, about 5-1/2" at the second step before the rear sump.
http://www.crankshaftcoalition.com/w...67/Oil_pan.jpg
azlogger 11-08-2012 09:36 PM
that's close enough for me thanks
E.Furgal 11-08-2012 10:19 PM
not really, as a vortec pan is a truck pan..
the car pan is different..
the f body pan the sump area is farthar back than a vette pan 1980 vintage..
I'd get the pan you plan on using and get the measurements off that..
azlogger 11-10-2012 03:16 PM
Aha! I just figured out that it will work after all to put the steering linkage in front on this car. which elimenates the need to go under the pan.
techinspector1 11-10-2012 04:51 PM
If the car was originally rear steer, swapping the spindles side to side to make a front steer car will not work. I don't know what you had in mind, I'm just trying to read ahead.
azlogger 11-11-2012 02:55 PM
as i said, i'm scratchbuilding this car so i don't have an "original car". in this case i will just have to use the front spindles from a vehicle with front steer. i was planning to go with pre-1981 ford truck spindles(which are rear steer), so i'll switch to post-1981(which are front steer). but if you foresee any problems with this please let me know!
