oil pan depth - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2012, 08:37 PM
Last journal entry: Front suspension update
oil pan depth
Hi, i'm scratch-building a car and need to know how deep the oil pan on a 350 chevy is at the FRONT. My steering linkage will have to go under the pan just a few inches back. I know there's a lot of different pans out there but i'm talking about just a standard, stock chevy pan. thanks
Old 11-08-2012, 09:00 PM
BOBCRMAN@aol.com's Avatar
There are many different stock SBC pans. You will have to be more specific.
Old 11-08-2012, 09:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
On my factory Vortec 350 pan (it's similar to the one below) I'm getting about 3-3/4" from the pan rail to the first (front most) step, about 5-1/2" at the second step before the rear sump.
Old 11-08-2012, 09:36 PM
that's close enough for me thanks
Old 11-08-2012, 10:19 PM
Last journal entry: was hoping for better than this
not really, as a vortec pan is a truck pan..
the car pan is different..
the f body pan the sump area is farthar back than a vette pan 1980 vintage..
I'd get the pan you plan on using and get the measurements off that..
Old 11-10-2012, 03:16 PM
Aha! I just figured out that it will work after all to put the steering linkage in front on this car. which elimenates the need to go under the pan.
Old 11-10-2012, 04:51 PM
techinspector1's Avatar
Wiki Edits: 326
If the car was originally rear steer, swapping the spindles side to side to make a front steer car will not work. I don't know what you had in mind, I'm just trying to read ahead.
Old 11-11-2012, 02:55 PM
as i said, i'm scratchbuilding this car so i don't have an "original car". in this case i will just have to use the front spindles from a vehicle with front steer. i was planning to go with pre-1981 ford truck spindles(which are rear steer), so i'll switch to post-1981(which are front steer). but if you foresee any problems with this please let me know!
Will oil pan seal with one broken oil pan bolt? Dougie Engine 2 03-10-2011 08:29 PM
350 oil ring depth jwallace1025 Engine 7 10-29-2010 08:30 PM
400 pan depth 327NUT Transmission - Rearend 1 10-28-2010 05:23 AM
Oil Pan Depth Bull_81073 Engine 3 04-21-2008 05:45 PM
ZZ4 Oil Pan Depth silvernblack Engine 2 06-11-2003 06:33 AM
