oil pan finish - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2013, 01:41 PM
Duane lxiv's Avatar
Last journal entry: headliner bow ends
oil pan finish
Has anyone refinished a Canton oil pan to make it look original?
If so what did you use?
Thanks
Duane
Old 04-27-2013, 08:54 AM
Old Fool's Avatar
I would put them in the blast cabinet, then SPI Epoxy and then top coat.
Trans Oil in oil pan mike Crawford Engine 21 04-09-2013 07:45 PM
Will oil pan seal with one broken oil pan bolt? Dougie Engine 2 03-10-2011 09:29 PM
400 SBC oil pan question..What quart size of pan do I need? heathj1 Engine 10 07-26-2010 09:26 PM
351w oil pan/ 5.0 oil pan interchange? problem solvers Hotrodders Site Suggestions and Help 4 05-10-2006 09:36 PM
oil pan-oil pump corenele Engine 13 05-14-2003 12:25 AM
