Oil Pan Gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2007, 08:10 AM
71 c-10's Avatar
just a kid and his truck
Oil Pan Gasket
Ok so I went to put my moroso pan on the other day with my summit timming cover and this one piece gasket from fel pro os34510t Well, the one piece gasket I guess it is made with the thick front lip, and the timing cover will only take a thin front seal, If i use the 4 piece cork set from the engine gasket kit I can make it all bolt togeher but I would rather not. I found this fel pro part number OS34509T which is a one pice with a thin front seal but it looks like it has no provisions for a dip stick? The timing cover part number is SUM-G6300W and the pan is a MOR-20200 the block is a 2 piece rear main sbc 350 and has provisions for a dip stick on either side. As you can see with the pan I have I would like to use the one on the passanger side. Any one know if this gasket will fix the problems I have? Thanks a ton for any help you all can be.
Old 10-30-2007, 09:01 AM
nitro_baller4692's Avatar
floppers forever
are you sure you dont need os34509t,there made for the same year motors just thinner on the timing caover seal area.
Old 10-30-2007, 09:22 AM
engineczar's Avatar
the os34509t is LH dipstick only
BSE Racing Engines
Old 10-30-2007, 10:02 AM
71 c-10's Avatar
I did see the os34509t when looking through our fel-pro book at the shop and put a link up. But according to engineczar it's a LH dip stick only ehh.. well then, I guess I could get that and send back the pan and swap it for a MOR-20190, which is the same pan, just for pre 80 blocks with the dip stick on the left. But that gasket is a thin front seal and will seal a left hand dip stick pan? If so that would be great and I'll get to ordering and mailing. Thanks for the replies
Old 10-31-2007, 11:32 AM
71 c-10's Avatar
does any one know if the milodon MIL-40100 or the Mr. Gasket MRG-5882 comes with a thin front seal and works with a pass. side dip stick?
Old 10-31-2007, 01:51 PM
I'm surprised. I must be out of touch. Correct me if I'm wrong, but I thought all SBC timing covers were the same and that only the oil pan changed to make the thick-thin change. I used a Fel Pro one piece, it had (2) dipstick holes, for either left or right configuration, and it went on pretty tight, but tightening the bolts, it did come down flush in front as it should. Or, at least, so it appeared.
Pat
Old 10-31-2007, 04:14 PM
GMC boogie's Avatar
You are correct. The difference is in the oil pan. Chevrolet used the thin front pan seal pan up until about '74,all with a drivers side stick. Around '74 a thick front pan seal pan was used and a drivers side stick until '79 or so.
A change was made to a pass side stick around '80 still using the thick front seal.
Old 10-31-2007, 04:23 PM
OK. So maybe 71-c10 has a problem with his oil pan, but the gasket should work fine with the timing cover. That said, I thought all the moroso pans were large radius (thick seal) pans. Musta missed that one. Or maybe, 71-c10 just needs to apply a little persuasion.
Pat
SBC oil pan/ gasket differences curtis73 Engine 6 02-11-2007 01:38 PM
Beware of one piece oil pan gasket for a Ford 460..... onebadmerc Engine 0 12-30-2006 07:00 PM
Installing Oil Pan Gasket EazyDuzIt102 Engine 4 06-11-2005 02:40 AM
351 Cleveland Oil Pan Gasket L88VETTELOVER Introduce Yourself 1 12-11-2004 07:43 PM
351 Cleveland Oil Pan Gasket L88VETTELOVER Introduce Yourself 1 12-11-2004 11:45 AM
