Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil Pan Gasket 69 Camaro
Old 03-01-2004, 03:01 PM
383MontecarloSS 383MontecarloSS is offline
How many miles are on the engine? Any excessive vibrating while the car is running? Do you torque it down to factory specs when re-installing the oil pan? Over torqing it could cause the seal to rupture and cause it to leak after a while....and my rule of thumb is to place a layer over the bottom and top the rear main seal so you get "extra" protection.
