Oil Pan Gasket Question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 10:39 PM
FastOrange's Avatar
I have a gasket set for a TBI 350 laying around and i was wondering if i can use my Fel-Pro One Piece oil pan gasket intended for a one piece rear main seal TBI 350 on a 1980 Two-Piece rear main seal 350.
I looked at the oil pans, and they look identical. down to the baffle inside.
Thoughts?
Old 06-14-2010, 01:00 AM
DoubleVision's Avatar
Far as I recall it`ll bolt right on as there really was no change to the oil pan or the seal when chevy converted over to 1 piece seal cranks.
Old 06-14-2010, 01:17 AM
malc's Avatar
Living At The Speed Of Life
The rear of the oil pan changed considerably,
larger radius, for the one piece seal.
Two piece rear.
One piece.
The one piece seal will not fit a two.
Old 06-14-2010, 12:36 PM
FastOrange's Avatar
Dang. Oh well.
Old 06-14-2010, 06:06 PM
fast68's Avatar
likes chevy trucks & boobies
55 to 79
80 to 85
then 86-up
chevy changed alot of things and ppl dont think so but they did,
oil sticks had several locations, lengths, and designs, oil pans changed, intakes and heads changed, oil filter types changed, and so on
crankshaft flexplate and flywheel mounting changed, in 86 also as did the rear main cap design due to the new RMS design
Old 06-14-2010, 06:09 PM
FastOrange's Avatar
i realize that, just thought i could get lucky.
Guess i have to buy a oil pan gasket and a rear main seal. I have everything else to drop vortec heads on it.
Felpro 1 pc oil pan gasket question for SBC lightning 55 Engine 11 06-10-2010 12:30 AM
Replacing Oil Pan Gasket on 1972 Nova 454 With Motor In Car - Help leejoy Engine 17 04-28-2008 01:58 PM
I cannot get my oil pan gasket to seal undy Engine 2 05-12-2006 05:21 PM
One piece sbc oil pan gasket? jtybt Engine 1 04-26-2006 05:33 AM
