Oil pan gasket and timing cover gasket, install? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 06:21 PM
I have 3 rubber gaskets for my OP and TC. There is one that has tabs on ea. End. Does that one go on the rear block? My motor is on the stand. Is the RTV, black hi temp o.k. To use in ea. Corner? Also the other 2 rubber gaskets one is a little shorter then the other, is the shortest of the 2 go on tc? Thanks
Old 07-22-2012, 11:11 PM
Silver Surfer's Avatar
Advanced User
Last journal entry: Light at the end of the tunnel
> Yes. The two tabs nest inside the rear main cap.
> Your gasket kit came with two different types of timing cover seals. Early versions of the small block used a thin timing cover gasket, later versions used a thicker gasket. The correct gasket will be determined by the OIL PAN, not the timing cover itself. Which one do you use? Check here: Oil Pan Gasket...thin or thick
> You will need to use sealant on all mating surfaces and both sides of the gaskets, not just the corners, but the corners are the most important/leak prone. Do not use a lot of sealant either, you don't want globs everywhere.
For sealant read this thread: Best oil pan sealant?
Old 07-23-2012, 12:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Go to
Amazon.com Amazon.com
. Hover over the image of the book on the upper left of the page and enter "oil pan seal" in the drop down box. Beginning on page 108 are instructions on sealing up a 4-piece pan gasket/seal set.
Oil pan and rocker arm cover gasket sealer Gearhead forever Engine 5 01-11-2009 10:04 AM
Oil pan gasket meschnebly Engine 5 07-08-2005 08:02 PM
New Cam Install - Oil pan gasket info requested. Siggy_Freud Engine 5 12-17-2004 11:00 PM
Mr. Gasket two piece timing cover nabx22 Engine 15 12-13-2004 05:39 PM
oil pan gasket the ernster Engine 3 04-17-2003 02:46 PM
