Oil Pan Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2006, 03:36 PM
Oil Pan Leak
I know about sealing an intake manifold front and rear with silicone and am a believer in it over gaskets but what about oil pans? Can you use it in place of the seals front and rear including the side rails?
Thanks for your help.
Old 12-03-2006, 04:40 PM
Go with a one piece pan gasket, and be done with it.
Old 12-03-2006, 04:56 PM
Oil pan leak
That would be a good fix but I have an old style SBC {1966) with a small front seal(stock pan} and as far as I know the one piece is only for the later SBC.
Old 12-03-2006, 05:05 PM
Fred, Fel-Pro FPP-1885, thin seal, $35.88 at Summit
Old 12-04-2006, 11:42 AM
Oil pan leak
Thanks for the info VETTEMAN I'll drive down to Summit to pick one up.
Old 12-04-2006, 12:27 PM
Oil pan leak
Vetteman unless I am reading the catalog wrong the Felpro# you gave was for a regular thin seal gasket set not a single piece.
Old 12-05-2006, 08:22 PM
If you go on their site, you'll see that's for a one piece gasket.
Old 12-05-2006, 08:34 PM
poncho62's Avatar
Wiki Edits: 5
I use the rubber end seals............dab of silicone in each corner. Don't overtighten the bolts..........Never had one leak.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
SBC truck block with car oil pan? curtis73 Engine 9 10-09-2006 05:06 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 01:47 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 09:58 PM
I have an oil leak that won't quit GHAutomotive Engine 4 09-06-2004 10:25 PM
