Oil pan leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2007, 10:03 AM
Oil pan leak
Hello everyone. I just completed a 7 yrs nuts and bolts ground up restoration on a 1949 Chevy truck and my motor has the following specs:
- Fresh (350) 4 bolt block decked bored and aligned (stoked down to a 302)
- (HEADS) 70 fuelie 2.02/1.60 valves all ported and polished with matching valve springs at set height
- (CRANK) Forged steel 3.000 stroke large journal 1178b first throw
- (RODS) Z28 with floating rist pins
- (PISTONS) plat & forged trw 11.80 to 1 compression ratio
- (Cam) Crane commander hyd lifters 488/467 at 1.5 matching lifters
- High volume oil pump, alum roller rockers, new push rods, etc.
It was just put on the road about a month ago and I continue to have constant front and rear oil pan leaks. My local mechanic shop has replaced the gasket 3 times to-date (tried 2 pieces and the thick 1 piece gaskets) an still leaking. We have also tried to glue the gasket on the block with spray glue, only put silicone in each front and rear seal cornors, etc. Everytime, due to a Fatman Fabrication front end, we had to jack up the motor a bit to get the pan out. Is it forming too much pressure...I have both a breather filter on one side and a PCV valve connected to my air filter on the other. It has an aluminum timming chain and oil pan cover that seems to align well...I don't know what to do anymore! Do we have to put it all together and leave it over-night for the silicone to dry? ...can someone help?
Old 09-20-2007, 10:26 AM
302 Z28's Avatar
Is your block a one piece rear main seal block?
Make sure your oil pan is fitting good at the rear main cap and also the timing cover seal. Do not accept the fact that they are new and should be fitting well, some pans and timing chain covers are made in China and don't fit worth a flip.
Use the one piece FelPro (don't accept any other brand) oil pan gasket and install it DRY, not even silicone in the corners it's not needed.
If you have a two piece rear main seal you might try installing the seal so it's mating line is 180 degrees to the main cap/block mating surface.
You said you have a PCV valve in the line that goes to your air cleaner, that is not correct. The PCV valve is installed in a manifold vacuum line, usually from the base of the carb or a fitting on the intake manifold. The PCV filter in your air cleaner goes to a hose that comes from your valve cover. The way it operates is a vacuum is pulled through the PCV valve. Negative pressure in the crankcase is then equalized through the tube into you air cleaner.
Vince
Old 09-20-2007, 10:47 AM
Oil leak
I agree with 302 Z28, get the PCV system connected and working correctly. That will probably solve the problem. That's really something pretty basic that a good mechanic shouldn't overlook.
Old 09-20-2007, 10:53 AM
PCV worked with my oil leak even when I have 2 breathers, the point it not to equalize pressure but relieve as much as possible. When those pistons move up and down you have massive pressure changes. If your pan leaks at idle thats a gasket/pan problem. If it leaks at higher rpms thats your PCV
Old 09-20-2007, 10:56 AM
302 Z28's Avatar
Equalizing the pressure was the wrong term to use....sorry.
Vince
Oil leak on S-10 2.8 V-6 fred56 Engine 4 09-22-2007 07:56 PM
Oil Leak de64 Engine 1 08-24-2007 02:37 PM
M.S. requested joke thread hotrodit Off-Topic 186 12-20-2005 12:26 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 12:47 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
