PCV worked with my oil leak even when I have 2 breathers, the point it not to equalize pressure but relieve as much as possible. When those pistons move up and down you have massive pressure changes. If your pan leaks at idle thats a gasket/pan problem. If it leaks at higher rpms thats your PCV
