Oil pan leaking like a siv - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-24-2014, 06:14 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
If you do pull the pan again, look at the seal area on the pan (see picture) and make sure it's not cracked. I had the same problem and come to find out the pan was cracked around the sealing lip on the front and rear. I welded it up and smoothed it down and installed the 1 piece gasket and it has worked fine since.
Another trick I do is apply RTV at the points shown in the picture, both on the pan side and the block side. Once you get the pan installed, let the RTV cure before starting the engine.
Name:	Pan Gasket.png
ID:	123826   Click image for larger version
  #17 (permalink)
Old 02-24-2014, 09:53 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
Thanks for the tips guys. I bought the pan brand new. Not chrome.
I'll also check the timing cover as well. There may be something wrong with the cover.
I checked the bolt for the fuel rod, all good there. No issues.
I'll check tomorrow night and get back with you guys.
Thanks again.
  #18 (permalink)
Old 02-24-2014, 10:05 PM
Applying rtv sealant to the four corners is something i do also and i also apply a thin layer of indian head gasket shilac to the block surface and to the bottom of the pan where it contacts the gasket and ive never had a leak.
350 Chevy oil pan leaking gasket Ed Baltera Engine 14 08-05-2012 02:17 PM
leaking oil pan on a 400 small block chevy jacob 1977 Engine 3 05-06-2012 08:52 PM
Will oil pan seal with one broken oil pan bolt? Dougie Engine 2 03-10-2011 09:29 PM
351w oil pan/ 5.0 oil pan interchange? problem solvers Hotrodders Site Suggestions and Help 4 05-10-2006 09:36 PM
leaking oil pan......need fix it tips Steve-0321 Engine 8 06-10-2004 09:09 AM
