Oil pan removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2007, 10:31 PM
super_silent's Avatar
Oil pan removal
Is it possible to remove the oil pan on a 67 camaro (327) by undoing 1 motor mount ? I would like to replace the oil pump and re seal the oilpan.
Thanks in advance
Old 12-11-2007, 12:02 AM
I don't think so, but you can do it if you jack the whole motor up a couple of inches. You need to turn the crank until the timing mark is at the 6:00 position, which lessens the inteference from the counterweights. Remove the distributor cap so you won't crack it against the firewall. Undo the fan shroud so the fan can lift it up as it rises. Remove the motor mount through-bolts.
Jack up the motor far enough that you can stick a chunk of 2x4 between each mount and its frame bracket. The pan can now be wiggled out carefully with the motor in this position. If you can get it up a little higher, it makes it a little easier.
I jacked mine up by the balancer using a floor jack with a piece of wood on the jack pad. Some say it's a bad idea, but I haven't had a problem from it in the nearly 30 years since I did it. This was on a '72 Nova, which uses the same front subframe as your Camaro.
Old 12-11-2007, 12:19 AM
Thanks Jim,
I have the motor pretty much apart, only the block & heads in there at the moment. I'll give it a try
Old 12-11-2007, 07:33 AM
poncho62's Avatar
Wiki Edits: 5
If you have that much off of it, yank it............You will have less laying on your back, less chance of the gaskets leaking, .......also, you can clean and paint it up to look better.
Old 12-11-2007, 08:05 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I agree with Poncho62, Your just
inviting problems by not pulling it.
Take care,
rich
Old 12-11-2007, 08:49 AM
I just converted the car over to a 4 speed and I'm trying to avoid pulling the tranny back out, although I agree it would be nice to have it on a stand and get it all sealed properly and painted. Could the motor come out without having to pull the tranny all apart again ??
Old 12-11-2007, 08:57 AM
poncho62's Avatar
Wiki Edits: 5
Not real easily.....Lining up the clutch would be a hassle again.
Your call, but if you have the hoist, I would pull the whole works. You could keep it all together. If you don't have the hoist, blocking it up will work, but a pain in the arse working under there.
Old 12-11-2007, 09:44 AM
302 Z28's Avatar
I agree with Poncho, pull the blame thing out and deal with it on a stand or on the garage floor. Less chance of goofing up the gasket than laying on your back. Go ahead and replace the rear main seal while you have it out also.
Disconnect it at the bell housing, no need to pull the trans.
Vince
Old 12-11-2007, 11:02 AM
.....makes sense, I think I'll pull it out and do it right.
Thanks very much guy's !
Oil pan question cdiedrick Engine 3 10-16-2007 07:57 PM
Wich oil pan you use on your 383 stroker? TVR383 Engine 10 01-30-2007 07:21 PM
oil leak rb8179 Engine 11 06-03-2006 03:07 AM
Oil Pan Removal sb72elcamino350 Engine 1 01-17-2004 03:35 PM
