Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil pan removal for 79 chevy malibu wagon
Old 01-14-2010, 09:25 AM
joe_padavano joe_padavano is offline
Originally Posted by timothale
on some cars you can loosen the motor mounts. jack up the engine and put wood blocks under the mounts. turn the crank to a get throw clearance, drop the oil pump pickup into the pan and then slide it out. still a real hassel. we have drilled out broken exhaust studs a couple of times then used a longer bolt and nut. but if you have my luck the one that broke is in a spot where you can't drill a thru hole.
I've found that by the time you go through all this trouble, you're really on a few bellhousing bolts and a hoist away from pulling the motor. Of course, the problem with doing that is the MIGHTASWELLS...
