oil pan seal for my 327 eng - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2003, 12:45 PM
Question oil pan seal for my 327 eng
i have a 65 impala with a 327 eng. does anyone know for the oil pans front seal if im suppose to use the thick seal are the thin one? ty for your help if u responed
Old 02-05-2003, 01:46 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
Post
hey its me again, btw iv'e got a 66 ht. iv'e got a 68, 327 in mine.
is it a stock pan and timing cover? that usually makes a difference i think cork works better than rubber but thats just my opinion. the most important thing to remember is snug is good but dont overtighten the bolts or you will warp the pan and then your screwed!! if you have a kit usually there is a piece of paper to tell you what applications to use. good luck and let me know if i can help with anything else
Old 02-05-2003, 02:28 PM
Post
FelPro makes a one piece oil pan gasket .....like the ones GM came up with for 86-up SBC's. I have one on my 283. They are about $37 but well worth it. The parts man who sells FelPro will get you the correct #.
Old 02-05-2003, 05:16 PM
Post
I agree with duece roadster, The Fel pro one piece pan gasket is the only way to fly. I thought they were only 25 bucks but maybe i was mistaken. Good luck and have fun
Old 02-07-2003, 06:39 AM
Thumbs up
thanks for ever ones help.i would have gotten a one peace but they i would have had to order it.i did put the oil ban back on with new cork gaskets.i used fel-pro.i relazed the front seal it suppose to be trimed on the ends and the think it was leaking before because it was overlaping the side gasget.but it look good now
Old 02-07-2003, 09:25 PM
Post
hi thanks for the advice.i got a cork one.but now i think i have a bigger problem.i put the new cam and lifters in.and i tryed starting the car but it only turns over one are two times and thats it.i dont think i set the timming right on the gears.is there anyway to set it without taking the timing chain cover off again? i also think the fuel pump isnt against the rod because i jst put a new one on so im fixing that tommorow
