oil pan/timing cover/vortec intake install - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-14-2014, 06:17 PM
Okay then. Advice noted and followed.
  #32 (permalink)
Old 04-15-2014, 03:28 PM
Had the shop weld on my pickup tube.. I used the purple spring in the oil pump.
ID:	137154   Click image for larger version
  #33 (permalink)
Old 06-06-2014, 12:33 AM
I am about to install my oil pan and I have a fel pro blue 1 piece gasket. Do I use any silicone on the oil pan or rear seal or timing areas?
  #34 (permalink)
Old 06-06-2014, 08:59 AM
ericnova72's Avatar
More for Less Racer
Just a small dab, at the very corners of the rear main cap to block junction, and timing cover to block corner junction. None on the oil pan side of gasket, and none in timing cover lip
Oil pan gasket and timing cover gasket, install? 39chevy Engine 2 07-23-2012 12:04 AM
Ford 5.0 Timing Cover to Oil Pan Seal Problems Dorf02 Engine 2 06-05-2012 07:19 PM
Timing cover / oil pan seal jstuhl Engine 3 09-07-2010 06:29 AM
Using Permatex Right Stuff on timing cover oil pan seal eric32 Engine 2 07-29-2010 02:29 PM
How to reseal timing chain cover to oil pan shockers69 Engine 2 06-21-2005 09:55 PM
