What we recommend is pre-assemble the engine.. . . snug the pan on with the gasket. Take a 1/8" wooden dowel rod with a dab of grease on the end. Put the greased in down the tube and into the pan. ..when it hits the grease will mark the spot where you need clearance. As Czar said, give yourself about an 1" around it for vibrational clearance.
Chris
