oil passage plug - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 01:28 PM
oil passage plug
Hi everyone, rebuilt my motor a few years ago with your help,just cant remember if I removed oil passage plug and replaced it afterwards!
Is there a way of checking without stripping motor down?
Sorry if its been covered before but it is difficult to search for!
Thanks in advance
Old 01-26-2012, 01:42 PM
engineczar's Avatar
Which one are you asking about, there are several? The three on the back are obvious.
BSE Racing Engines
Old 01-26-2012, 01:49 PM
Its the one under the main bearing saddle,its half way down a hole,sorry dont know the proper name for it!
Old 01-26-2012, 02:00 PM
engineczar's Avatar
If you take out the oil pressure sending unit (or fitting) that is on top of block, next to the distributor you can insert a small diameter rod or even a coat hanger down the hole. From that end the plug is roughly 8 1/2 inches down. Without the plug the main cap is roughly 10 inches or so.
BSE Racing Engines
Old 01-26-2012, 02:58 PM
Great, thankyou for that info!
2-3 acc passage bodie filyaw Transmission - Rearend 0 01-31-2011 05:19 AM
Rear water passage on SBF Arrowhead Engine 2 08-21-2008 11:03 AM
Oil passage Plug murph8868 Introduce Yourself 1 07-25-2008 01:26 PM
Big Block Oil Passage PAS55 Engine 3 05-28-2005 08:13 PM
Blocked coolant passage. Siggy_Freud Engine 2 01-17-2005 03:20 PM
