Oil Pick up tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2005, 06:41 PM
Oil Pick up tube
Very simple basic question and I can't find the answer. Does the oil pick up tube on a 5.0 ford engine require a lock washer to mount it to the main bearing cap? The engine I got was in pieces and I can figure most of it out. Thanks for the help!!
Old 11-27-2005, 07:51 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Not if the nut is tight enough.
Old 11-28-2005, 07:52 PM
Intrik, Thank you for the info. There was a baggie with two bolts and a nut that are the right size and thread pattern but the nut was tight like it had been crimped. I am using locktite with it. Thank you for the info
Old 11-29-2005, 12:13 AM
techinspector1's Avatar
Wiki Edits: 326
Just a personal observation from years of wrenching.....
Lockwashers have no place on a car or motor....Period.
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 08:39 AM
No oil pressure cleancut Engine 12 04-30-2004 11:35 AM
oil coming up through dipstick tube stoneyone2001 Engine 10 04-12-2004 10:10 PM
Checking oil pressure after installing a new pump. WeberVette Engine 8 12-11-2003 10:34 AM
Low idle oil pressure chuckellison Engine 4 03-03-2003 08:20 AM
