Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil pick-up tube to pan clearence
Old 08-21-2012, 04:51 PM
scholman scholman is offline
farmwalker,
Your way of measuring the clearance will work it is kind of hard to know if you put too much pressure on the pan causing it to bow up a little. I use some of my daughters play dough. I put a ball of the stuff on the pick-up then I bolt the pan in place using a gasket. Take the pan off and then measure the play dough where it has been flattened. I believe 1/4 of an inch is fine. Any closer and the pump will not be able to suck up enough oil to supply the engine.
