Oil pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2011, 09:35 PM
badknuckles's Avatar
you talkin to me?
Oil pressure
Could low oil pressure cause a valve clack at all rpms but not set off an oil light? If so what range would the pressure have to be?
Old 06-23-2011, 09:37 PM
you talkin to me?
Yes I realize that healthy oil pressure is between 30 and 60
Old 06-23-2011, 10:07 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Sound like your timing may be a little high... Did you check the timing???
Old 06-23-2011, 11:28 PM
you talkin to me?
Timing high? How so?
Old 06-24-2011, 07:17 AM
delawarebill's Avatar
oil pressure ????
what is the pressure while idle and running down the road (rpms)... if its very low all the time, like under 10# then u have another problem.. u didn't say what motor.. but chebby's will idle hot at about 15# and not tapping... maybe u need to readjust or u have a bad lifter????
Old 06-24-2011, 07:53 AM
you talkin to me?
It is a 318. Did not make any noise when I got it.put a new cam and lifters in and now the whole valve train clacks away. Everything looks good lifters etc, now I'm on to oil pressure. I did knock away some carbon while in there so maybe plugged screen. But I know the oil pressure gauge works and it is not lit.
Old 06-24-2011, 08:33 AM
Well.. When I post this.. You didn't have much Info on the motor..I said timing because when the timing is to high you will get some lifter noise.. Now if the lifter's isn't adjusted right that will also do it... Now.. as far as low oil pressure..You really never said you had low oil pressure..This is what you where asking..I was just pointing out a few things that could cause it..Good luck..
((((Could low oil pressure cause a valve clack at all rpms but not set off an oil light? If so what range would the pressure have to be?)))
Old 06-24-2011, 09:17 AM
you talkin to me?
I will actually r check the timing,i was just unsure how that caused valve train noise....at this point asl tips are helpful. Thank you
Old 06-25-2011, 06:43 AM
Is the new cam ground on a reduce base circle? This would cause your pushrods to be too short.
Excessive timing could cause pinging/rattleing from detonation.
If the lifters are actually collapsing, it could be from the carbon you knocked into the oil pan. Lifters have some of the smallest clearences you'll find in a motor, doesnt take much grit to plug one up, or stick to the plunger.
Old 06-25-2011, 07:32 PM
you talkin to me?
i believe it is a reduce based circle but how can i be sure?
Old 06-26-2011, 02:38 AM
Call the manufacturer.
Old 06-26-2011, 03:48 AM
General Martok's Avatar
The shaft that goes from the cam to the oil pump my be stripped in side the
pump,by the cam is a gear drive to the pump that you meshed the teeth
together ,if this has happened the pump will still turn but not enough flow for
the motor.Mopar small blocks are known for this.Any questions dont hesitate.
Oh the shaft is a hexagon shape at the end that goes into the oil pump.
here something to look at
http://www.google.com/imgres?imgurl=...iw=874&bih=471
Old 06-27-2011, 06:43 PM
you talkin to me?
Would like to say, the cam manufacturer checked out the play and provided me a free set of pushrods 60 over. Yay once again to local businesses
Pacific Pressure pressure washer allancarswell Garage - Tools 0 06-01-2010 10:12 AM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
Oil Pressure Guage = Fuel Pressure Guage topdogger Hotrodding Basics 7 06-24-2007 08:55 PM
Crankcase pressure effect on oil pressure? cboy Engine 8 06-12-2005 08:04 AM
