oil pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2012, 10:33 AM
oil pressure
well i check the oil pressure on my 58 235 chevy and cold it was 40 psi and hot it about 5 psi so that might explain why the lifters are the way they are ,so i might not need lifters ,and that might explain the knock ??so i guess i need to change the oil pump first and see ,
Old 07-08-2012, 10:43 AM
vinniekq2's Avatar
oil pressure
what oil weight oil and is it a mineral oil?
Old 07-08-2012, 12:35 PM
i was using rotella 30w
Old 07-08-2012, 12:45 PM
vinniekq2's Avatar
low pressure
several things can cause low oil pressure,like worn bearings.If you go to the trouble of dropping the pan,consider popping a cap and checking the bearings for wear and discolouration.You can use 50w mineral oil.Also check your oil pressure with a different oil pressure guage if you can borrow one.
Are there any lifter noises at idle when the engine is hot? I assume you change oil regularly?let us all know how you make out,thanks.
Old 07-08-2012, 12:48 PM
well only had the car about a month ,, i drove the car today and the lifter noise wasnt bad ,i almost have the oil pan off now i took a brake ,i dont know what kind of oil was in the car when i got it ,, could the pump be bad even though i have 40 when cold and 5 hot ? ohh well i'll see when i get the pan off
thanks for the replies
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
Please help to diagnose- engine with no oil pressure. Oil pump failed? killerformula Engine 4 12-26-2006 10:25 PM
fram oil filter lower oil pressure elvis 66 chevelle Engine 33 09-14-2006 04:36 PM
Crankcase pressure effect on oil pressure? cboy Engine 8 06-12-2005 08:04 AM
rebuilt engine no oil pressure in oil galley bmedina103 Engine 9 10-07-2002 10:37 PM
