Oil pressure on 350 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2003, 07:44 PM
BigMac's Avatar
1949 Chevy Truck
My 350 has very low pressure when at idle. I just changed the oil and also added a new guage. It still shows that its low. Is my next step a new pump?
Old 09-01-2003, 07:49 PM
DoubleVision's Avatar
how low is it? how many miles are on the engine? keep in mind, most gauges are not accurate under 10psi, some aren`t under 15. As long as the engine has a 10 psi increase per 1000 RPM it should be okay, and when at idle you don`t here any valves clattering, however, if there is high milage on the engine, you can do this little trick, go to your nearest car quest parts store, get a can of "Sea Foam" pour it in, let the engine idle for 15 minutes, then change the oil and filter, you`ll be amazed at the crud that will come out with your oil.
Old 09-01-2003, 07:53 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
If its an electrical gauge is the old sending unit compatable with the new?
Luv the smell of NITRO in the morning.
Old 09-01-2003, 09:18 PM
BigMac's Avatar
1949 Chevy Truck
The new one is electrical with a new sending unit. Pressure shows around 15 psi.
DoubleVision, I have never heard of "Sea Foam"
Old 09-02-2003, 03:02 AM
15 PSI is fine at idle, I have a can of sea foam in the shop. Need more proof? check this site:
http://www.seafoamsales.com/
not suprised you`ve never heard of it, this stuff has been around over 50 years.
Old 09-02-2003, 06:48 AM
OddsNEnds's Avatar
New Member
DoubleVision, I'm gonna try your SeaFoam tip on my next oil change for my El Camino. It seems to have a sticking lifter, hope the SeaFoam helps. Thanks for the tip.
Old 09-02-2003, 08:50 AM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
yeah, the only problem with Seafoam is when the "CRUD" is creating a seal on your otherwise SPENT seats...you clean out the crud and suddenly you're in skewed city. lol
Old 09-02-2003, 11:18 AM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
I'm going to have to try and find this stuff, hey one question should do a second oil change after flushing with this? i.e. Run Seafoam, change oil, run a day or 2 and change oil again?
Regards
Mark
Old 09-02-2003, 12:33 PM
BigMac's Avatar
1949 Chevy Truck
It sounds like I am not the only one to ever hear of Sea Foam. I looked at the web site today and the product sounds great. Just changed my oil yesterday and going to run it for a day or two and change again after Sea Foam. Hope it works.
Old 09-13-2003, 10:01 PM
BigMac's Avatar
1949 Chevy Truck
I just used the Sea Foam on my truck today. After only 150 miles on the oil, it looked like I had 3000 miles on it when I changed it. I think it did clean the engine a little.
