Oil Pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2004, 11:20 PM
Novaman78's Avatar
Kill It & Grill It
Last journal entry: New door panels
Oil Pressure
How long does it usually take to get the ol pressuer built up on a freshly rebuilt engine.
Old 08-13-2004, 11:50 PM
GoneNova/406's Avatar
since your oil pump is turned off the dist.gear and the cam turns it i'd say as soon as you start it.you are priming the oil pump with a drill first though,aren't you?you can look at the oil pres.guage wile turning the oil pump with a drill and see your pres. before you start it the first time.that way you know you have oil pres. befre you start it and avoid those nasty noises.
Old 08-14-2004, 06:35 AM
Novaman78's Avatar
Kill It & Grill It
we tried to prime it before we started it but we couldn't get any pressure and soon as we saw i had no pressure with the engine on we shut it off. Im taking the pan off today and going to check out the pump and pickup. Its a new melling high volume pump and stock pickup with stock pan. is there something wrong with this set up why i wouldn't have pressure.
Old 08-14-2004, 08:22 AM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Galley plugs were installed behind the cam gear?
If it is a big block make sure that a small block oil pump drive shaft was not used. Make sure the shaft is engaged in the pump and distributor regardless of which was installed.
Old 08-14-2004, 08:19 PM
edge's Avatar
Time is short, are you ready?
Verify Your Gauge First!
Before you drop that pan, check your gauge against one that you know is working. Good luck, Ed. www.edgesz28.com
Old 08-14-2004, 08:30 PM
LilSmoke's Avatar
What did u use for a primer? if it isnt as a dist, press wont build up because the galley isnt closed off.
Old 08-14-2004, 10:35 PM
Novaman78's Avatar
Kill It & Grill It
Figured it out. There is a oil plug under neath the main bearing cap in the very back. I put the plug in but not all the way so it wasn't getting oil. But i do now its about 60 psi. Tomorrow i need to get the paper gaskets for the carb where ou adjust the float bowls at and some tranny fluid. Carb needs adjusted just a little. Should have it going tomorrow.
