Oil Pressure & Distributor. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2006, 09:13 AM
Cobra Pilot
I have a built 351C in which I was running a Davis Unified Distributor. A special note was given for Ford engines. It stated not to run over 65 psi oil pressure and to drill a .030 hole in the lifter galley plug behind the distributor. What effect does this much oil pressure have on this distributor, gear or the cam?
Thanx,
Everett.
Old 05-15-2006, 09:44 AM
351C has "oiling issues".....that's why the special note
goooogle will find you a "how to improve the Cleveland 351 oiling system and why"
article might be in the knowledge base link above
email to DUI and ask why 65lbs and a hole?
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
lets have a oil pressure discussion k-star Engine 9 02-05-2007 11:31 AM
oil pressure sending unit? Brian Morency Engine 2 07-21-2004 03:43 PM
Low oil pressure at idle on rebuilt 350 Palmtrees57 Engine 25 02-13-2004 10:30 AM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
