oil pressure gauge reading zero... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2012, 02:54 PM
Prof. T. Soggmeyer's Avatar
Plan B
I installed my dolphin gauge cluster in my 49 3100 and put in the sending unit that came with it. Gauges have good ground and all needles come to life when the ign. is in the on position. Oil squirts like there is no tomorrow out the port. Anyone have any ideas?
Old 04-12-2012, 03:17 PM
T-bucket23's Avatar
Wiki Edits: 26
Bad sender or wiring. You should be able to check the sender with an OHM meter.
Chet
Old 04-12-2012, 03:18 PM
Without knowing some other information such as type of sender and so on, it would be hard to diagnose the issue.
Old 04-13-2012, 08:29 AM
Frisco's Avatar
Glad To Be Here
If you used sealant or teflon tape on the pipe threads of the sending unit, you may no longer have a ground connection at that point. Check for ground from the sending unit body to the block.
Old 04-13-2012, 08:34 AM
Plan B
I originally had teflon on it, but removed trying to figure it out. Going to call Dolphin here and see if they can give me the ohm reading it should have.
Brad..
oil pressure reading... fireforsin Engine 29 10-28-2013 05:03 AM
oil pressure gauge reading 0 Prof. T. Soggmeyer Electrical 2 03-26-2012 09:50 PM
Oil pressure reading when car is off? turchiac Hotrodding Basics 2 07-10-2010 06:18 PM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
oil pressure gauge 69 chevelle SS Engine 2 06-22-2003 08:18 AM
