Oil Pressure Guage = Fuel Pressure Guage - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2007, 01:01 PM
topdogger's Avatar
Newskool
Last journal entry: New, Used grill arrived!
Oil Pressure Guage = Fuel Pressure Guage?
Some may remember my post a few days ago about using an oil temp guage for tranny temp. I have another question though. The guages I use are limitted in variety but almost all are electronic. Could I use an electronic oil pressure guage for fuel? The style of guages I'm using doesn't currently include a fuel pressure guage but I would like to install one. Is there a standard for the electrical components of guages? Another thing I was thinking of doing is buying just the electronic sending unit for fuel pressure and attaching it to the guages available that will match.
Will this work?
Here's a picture of what my current oil pressure sender looks like. It's very similar.
Old 06-22-2007, 05:18 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
What is the range of the oil pressure gauge you have?
Don't most electric oil pressure gauges start reading at a higher point than a carbed system will operate at? assuming a carborated engine.
Old 06-22-2007, 07:31 PM
topdogger's Avatar
Newskool
My oil pressure guage actually starts right at zero. Thats why I was thinking it might work. There would be a lot of headroom but I figure it would show up fairly accurately. The guage goes from 0-100 PSI and sweeps past just under 3/4 of the circle.
Old 06-24-2007, 12:26 PM
bentwings's Avatar
bentwings
A gage is a gage so it won't matter. It will be just the face numbers and lable that will be different. Be carefull about running gas into the driver compartment. Like don't do it!!
Old 06-24-2007, 12:48 PM
techinspector1's Avatar
Wiki Edits: 326
Old 06-24-2007, 04:54 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Couple of things you MAY not have considered...
First the Media is different, Oil is MUCH thicker than Fuel (and much hotter)....Chances are If it registers at all, It will be grossly in error...
The Sender Resistance MUST be matched to the Resistance of the Gauge in order for it to operate. You Can't just mix and match any gauges.
Fuel MOST Likely will attack any non metallic parts over time, and the sender MAY end up spraying fuel on each stroke of the pump when it does start to leak, leading to a fire..
Just some Food For thought..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-24-2007, 07:15 PM
topdogger's Avatar
Newskool
So in other words I would be much better off without a fuel pressure guage. This isn't a high performance application. I simply need another guage to fill the spot and I figured it would have been nice to have a fuel pressure reading.
Old 06-24-2007, 08:55 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Well, If you can get a Fuel approved sender..and don't put a whole lot of stock in the readings..I guess it will be OK..But I wouldn't do it personally..
You can get a pressure gauge / regulator at the Auto parts store Cheap enough..mounts on the inlet line Or get some AN plumbing for it to go to the mounting area..But again, a dash gauge for fuel pressure isn't that important to me..Either it is or it isn't..
Doc
Innovations
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
Crankcase pressure effect on oil pressure? cboy Engine 8 06-12-2005 08:04 AM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 10:27 AM
No Oil Pressure with normal operating tempature jrm123180 Engine 3 03-03-2004 02:56 PM
Fuel Pressure Variance slomotion Engine 2 04-02-2002 01:25 PM
