oil pressure issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2009, 12:20 PM
oil pressure issue
i have a fresh small block chev with pistons,cam,heads,the fairly average street parts.Now,when i fire it,it runs about 50 lbs. of pressure.As it warms up,pressure drops like a rock the hotter it gets.The pump is a stock peice with a heavier spring but thats about it.Right now im running 30w oil which is probobl a lil thin,but not that thin.Crang journals are at stock dim. with a little polish and the block isnt cracked.I really hate to pull it again too since its in an S10..When i primed it it had all sorts of pressure,just seems to be when it warms up.Could some thing be damaged ot missing?This is a Vette Lt T1 block,fuelie heads,10.5:1 pistons,gear cam drive,but stck crank and rods,wich were in very good shape.Any thoughts would be great...thanx
Old 10-31-2009, 12:24 PM
DoubleVision's Avatar
How low does it get? does it get better when the RPM rises?
Old 10-31-2009, 01:07 PM
GXR11's Avatar
gas milage? wrong hobby buddy
ive always heard that a good rule of thumb is 10lbs. of pressure for every 1000 rpms.. dont know how true this is.. but i have never had any problems going by it
Old 10-31-2009, 04:47 PM
fast68's Avatar
likes chevy trucks & boobies
10 seems high to me
i have been told 7-8 lbs per 1000rpm
and thats about what every chevy engine i have ever had has been
they always are super high when cold thehn drop quick when hot
normal
no worries here it seems,
drive it,.
unless the toop end is rattling away or it reads zero pressure..
also i dont trust any pumps except stock oem ones
dont need extra pressure or volume
waste of time there..
oem pumps pump plenty of oil
Old 10-31-2009, 05:40 PM
Yes,pressure does risewith RPMs.Also it isnt making any noise.Seema to be pretty good there,although it may be hard to hear over the gear drive..lol.But no ticks or thumps or anything like that.
Effects of too high oil pressure ? y2k600f4 Engine 4 03-19-2009 02:13 PM
new engine, oil pressure probs montea Engine 35 06-02-2006 01:37 PM
chevy small block possible low oil pressure? ruski Engine 24 04-24-2006 10:18 PM
No Oil Pressure!! MartyMart9@aol.com Engine 43 04-26-2005 07:37 AM
It's alive...finally AngliaBob Engine 5 02-19-2005 01:46 AM
