Oil pressure issues this maybe some of the problem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2009, 09:32 PM
CNC Blocks Northeast
I have seen on all GM rear caps SBC & BBC we have found then to be restricted because of the casting hangs in past the oil port of the oil pump and we have seen some that have been block 60%
Take a oil pump cut it off like the one on the right.
The cap on the left has been opened up to match the oil pump.
The cap in the middle had been marked with a marker showing how much has to be removed.
The cap on the right you can look in the oil port and see the casting blocking the port.
Even on the after market blocks they some times have to be touched up.
Old 12-31-2009, 01:50 AM
4 Jaw Chuck's Avatar
Its a little known mod and few people know about the issue, thanks for brining it up again and showing the proper method to solve the problem!
With pics yet!
Outlawed tunes from outlawed pipes
Old 12-31-2009, 05:39 AM
Steel's Avatar
The Ultimate Lurker;)
That's great info!! Thanks for the quick study
Old 12-31-2009, 07:01 AM
sqzbox's Avatar
My pipes are my music
I wonder if GM knows this?
Aluminum Heads scenario of potential problem of cause of oil consumption (long) y2k600f4 Engine 37 09-14-2009 05:22 PM
W.O.T. oil pressure problem Purple #55 Introduce Yourself 3 06-22-2008 09:44 PM
Oil Pressure Problem - Help leejoy Engine 3 04-26-2008 06:46 PM
oil psi problem w/350 A355CAMARO Engine 2 04-19-2007 07:25 AM
Found low oil pressure problem.... kc_ksom Engine 2 09-06-2005 07:01 PM
