oil pressure! motor new, start up 75 lbs ! now1lbs at1400 rpm
please help! pro built 355 small block. mellings hi volume oil pump. at start up ran at 2500 rpm for 30 minutes for cam break in. oil pressure stayed at 65 to 75 psi throughout. engine temp never over 170 degrees. retourqued intake, heads, and run valve lash, changed oil and filter and added oil cooler and adapter for cooler lines. started back up had leak at adapter, turned off engine. took adapter and cooler off. restarted engine and oil pressure was at 35 psi at 2500 rpm. at idle pressure drop to1 to 2 psi. check oil psi gauge, oil level ect. removed valve covers, started engine and at idle oil pressure remained at 1 to 2 psi. oil very slow and weak comming to rocker arms. shut engine down. dont know if complete info on engine is needed, everything is new. thank you for your time. im at my whits end. do not want to pull engine unless you all think it nessary.
10 psi per 1000 is at max rpms not 10 psi at 1000 etc. ie 6000 rpms=60 psi safe. cut filter open and check for filings and that will tell u whats going on. I can peg a gauge with a speed handle, so something is wrong.
Kind of a longshot....but a broken or jambed up pressure relief spring or valve in the oil pump. I had a Buick 400in that suddenly had no oil pressure at idle but did get decent pressure at 2000rpm or above. Turned out to be a nylon tooth from the cam gear had wedged in the pressure relief valve and was hanging it open.
My question is was the pump primed properly before being installed in the engine? Also a high volume pump will suck a stock oil pan dry before the oil has a chance to drain back down and if this is the case you'll either need to change to a different oil pan or change pumps. Either way 1lb of oil pressure is too scary to me and could eventually wipe out the bottom end, I'm not used to anything under 30lbs. at idle warm.
Do you have a plastic line going to your guage?If so make sure line is not crimped somewhere.
