Oil pressure pegs when block is grounded - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2011, 07:52 PM
Hey guys, I got my ride all hooked up and everything works perfect until you ground the block. All my electrical (lights, gauges, etc.) is grounded straight to the battery so everything works good. When you ground the block to the battery or the block to the frame and frame to the battery my oil gauge pegs out at 100 and won't work at all. Even trying to ground the starter so you can start it pegs it out, I used this same harness, gauge, and sender before and it worked fine. Could my sender have gone bad?? It's an autometer elec. Oil press gauge. Iv never had this happen before. Any info would be appreciated, thanks
Old 04-15-2011, 09:23 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i would guess that its the sending unit
Old 04-16-2011, 04:57 AM
EOD Guy's Avatar
Take a temp jumper wire and ground one end..... touch the other end to the sender housing (not the wire coing out of the sender) if it pegs....I'd say it's the sender
Old 04-16-2011, 05:38 AM
Thanks guys, i tried that too and it still pegs. I guess I'll pick up a new sender today, never had one go bad so didn't know what it would do. But if the blocks not grounded and you turn on the gauges, the needle raises to 0 like it's suppose to. Just an odd case.
Temp, Oil and Gas Gauges Pegs when HEI hooked up. lazydawg Electrical 1 04-09-2010 10:39 AM
I think I need grounded.... schnitz Electrical 7 04-29-2007 05:28 PM
Tach pegs when ignition is turned on toddiyaayas Electrical 1 06-27-2006 02:42 PM
Grounded or not Tomz69 Electrical 6 03-23-2005 09:40 PM
Grounded m-hauler Electrical 7 10-26-2003 09:17 PM
