Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil pressure prob. (unusual)
Old 12-24-2006, 09:12 PM
Gokussj5okazu's Avatar
Gokussj5okazu Gokussj5okazu is offline
Last journal entry: 336 Stroker: Teardown
That's not extremely unusual if you think about it. It holds good pressure when it's cold because the oil is thick, but thins out alot when it gets hot. Sounds like you just need to run a thicker oil. What weight are you using?
