Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil pressure prob. (unusual)
Old 12-25-2006, 06:44 AM
aka Duke of URL
Originally Posted by curtis73
Possibly a bypass valve stuck open?
Did you use a HV pump (MELLINGS hopefully) and did it come with two springs? You might want try the higher pressure relief spring and see what happens. Did you take a mechanical oil pressure reading at both the front and rear galleys?
